Get NordVPN Deal - Save 51% with 2 years plan at $3.99 per month Get Exclusive Offer X
Safer And Cheaper Flight Tickets With VPNs
Are you planning to fly to a distant island this vacations, or flying to a foreign country for a work meeting or visiting your family in your native country? Wait and read this article before you impulsively book your flight tickets in the excitement.
We will help you save money on your flight tickets and guide you to keep your data and flight-booking activities safe, all you need is to have a good VPN.
Not many people know the wonders a VPN can do. This is especially true when booking flight tickets. Use of a VPN when you book your flight ticket can be of extreme help.
In today’s time, when air transportation has become one of the most commonly chosen mode of transportation, this sector has grown to an enormous size.
There are several travel websites readily available to you from where you can find and book tickets at your own comfort and convenience.
However, if you do not make use of a VPN while finding and booking your flight tickets, you are unknowingly uncovering yourself to needless risk.
Moreover, by doing so, you are also increasing the prices of the flight tickets for yourself with even having a hint of that possibility.
Through this article, you will get to know how useful a VPN could be for the purpose of booking flight tickets. Keep reading further to know how VPNs can help in safer and cheaper flight ticket booking.
Quick Guide: How to get started with a VPN?
  1. Subscribe to a VPN like NordVPN.
  3. Sign Up for the service and log into your VPN app
  4. Connect to a suitable server.
  5. Visit the sites you want without having to worry about privacy and safety.
How does a VPN make it safer?
It is obviously possible to book flight tickets without using a VPN but doing the same by using a VPN is comparatively safer.
Below mentioned are some of the ways how the VPNs do so:
1. Conceal your data
VPNs help in keeping all the internet traffic encrypted. The data traffic passes through a private and anonymous VPN tunnel which makes it nearly impossible for the third parties to have access to it.
This extra protection is very much required while sharing sensitive details like credit card details while buying airline tickets.
2. Hide your IP address
While booking a flight, what we often do is search the web for comparisons in order to save as much money as possible.
However, what we often ignore is that almost all of these websites you visit make use of methods such as cookies and geological location which help them in collecting data for targeting their potential customers.
So in order to save your money while booking flight tickets, you must make use of a VPN so that the external agencies do not get a glance over your interests and requirements.
What happens when you use a VPN is that the tunnel that would be used for channeling all of the traffic and the server would be maintained by the VPN you use.
The VPN assigns your device an IP address which helps you keep your activities untraceable by external agents.
3. Ensure your privacy
If you use a VPN while accessing the web, all your data is kept private and secure.
The top VPNs has no-log policies and keep your data safe from any third party.
How does a VPN make it cheaper?
All the airlines use AI technology as well as complicated algorithms to analyze the information you fill and then determine the fare in such a way that they can gain the maximum profit. Below mentioned are some ways which will help you get cheaper flight tickets:
1. Circumventing airline algorithms
If you don’t use a VPN while opening the browser for booking flight tickets, the airlines automatically get your IP address. This will lead to them knowing your location and saving it for later use as well, hence boosting their profit.
Everyone wants to get cheaper flight tickets but make the mistake of not using a VPN. The airlines save your data and use it to increase the fare every time you search for a ticket without using a VPN.
In order to avoid this, you are required to hide your actual IP address from the airlines, which can only be done with the help of a VPN. Getting yourself a subscription of a VPN will offer you more discounts.
2. Yours location is spoofed
As already mentioned the airlines use your information including your location to determine the fare. This means the country you are in affects the charge for your ticket.
In case you are in a country, whose location will cost you more, a VPN allows you to change your actual location with a fake location. By this you can easily compare the prices from different countries and then choose the suitable one.
3. Customer profiling is avoided
The airlines use all the information gained through customer profiling for their benefits. This can lead to an individual seeing some fare for a ticket and the other might see a different fare for the same ticket.
The airlines determine the fare depending on various factors. It even includes the device you are using while booking. In case of expensive devices and affluent locations it automatically shows high fares.
Using a VPN will allow you to cloak your IP address which will save you from the strategies used by airlines to charge high fares.
How to use VPNs
Given below are the simple steps you have to follow to ensure safer and cheaper fight ticket booking process:
  2. Install the VPN on your device.
  3. Open the VPN and then connect to a server of the desired country.
  4. Then clear all cookies or you can also use incognito mode.
  5. Open your browser and search for cheap flights safely.
You may be required to switch between servers so as to find cheap prices for flight, but that’s about it! It’s as easy as that to save money on flight tickets while ensuring safety.
Most recommended VPNs
1. NordVPN
NordVPN LogoGet 68% offTry NordVPN
  • Fast and secure Internet
  • Strict no-logs policy
  • Enjoy uninterrupted full range streaming
  • Connect up to 6 devices
  • Onion Over VPN - Combine NordVPN encryption with the anonymity.
  • Multi-factor authentication
  • Split tunneling support
  • Get a Dedicated IP address
  • Mask your IP
  • No data leaks
  • Unblock Netflix, Prime Video, Hulu etc
What makes it more attractive is that six connections at the same time are provided on each of the subscriptions in addition with the Netflix streaming.
This VPN is known to be the all-rounder VPN with the availability of high-speed internet and reasonable price.
It has a simple UI which makes it very easy to use even for beginners. It is popularly used to unblock the contents which are geographically blocked in platforms like Hulu, Amazon Prime, Netflix, Disney, etc.
One of it’s best qualities is the guarantee of 30 days for returning back the money which makes it riskless. Incase you do not like the app after trying it, you could easily get 100℅ refund.
2. ExpressVPN
express vpn logoGet 49% off nowTry ExpressVPN
ExpressVPN’s features in a glance
  • 160 VPN server locations in 94 countries all over the world.
  • Masking IP Address
  • Easy to use on every device like Windows, Mac, iOS, Android, Linux, routers etc.
  • Split Tunneling which lets you route some device traffic through a VPN
  • Kill Switch keeps your data safe if your VPN connection drops.
  • No log policy
  • It blocks malicious and ads.
  • It lets you bypass ISP throttling.
  • Wide-ranging payment options
ExpressVPN is the best option to be used if you require a VPN which provides high security as well as high encryption. The VPN is based on the British Virgin Islands where there are no laws for data retention.
Hence, your data will not be kept with the company and no other party could request to access your data which makes it completely private and secure.
OpenVPN, L2Tp-IPSec and IKev2 protocols are used by ExpressVPN which are popular for being the most reliable and safe security protocols.
It has more than 3000 servers in around 94 countries which offer upto 100Mb/s speed of internet. It allows you to stream Hulu, Amazon Prime Video, Netflix, Disney+ and many more in the best streaming quality (Ultra HD quality).
They also provide you with the 30 days money-back program through which you could easily get your full refund in case you want to withdraw from this VPN.
With this, there is also a feature of live chat available 24/7 to help you deal with all your problems. In case you need, there is also an option which provides you access to a hidden page meant for subscriptions of low price.
Conclusion
It is undeniable that using a VPN can keep your activities safe as well as help you in saving money while booking flight tickets. A VPN gives you protection wherever and whenever you’re browsing on the internet, also when you are connected to a public wifi.
However online safety should not be an issue to be stressed on when planning a trip for you vacation. VPNs are an essential part of every individual’s online life.
Whether you are streaming your favorite show, browsing a website or paying bills, maintaining privacy as well as security is very essential. Online privacy and security should be stressed by everybody in today’s time.
Using a VPN is one of the best strategies which provide a layer for extra protection against the common threats we are exposed to when we are online.
Leave a Comment
Your email address will not be published.
