Get NordVPN Deal - Save 51% with 2 years plan at $3.99 per month Get Exclusive Offer X
A Complete Guide Of VPNs: Setting Up And Use
VPN is a common term in today’s time. Even if you have never used a VPN, you must be aware of it or at least heard of it from somebody who has used it at least once.
As the world is switching to digital mode for all their work, from registration for anything to businesses, the use of VPN has increased significantly.
VPN expands to Virtual Private Network. It helps you in maintaining complete anonymity and privacy while you are online.
What it does is that, while you are connected to a public network, it creates a private network just for you where your internet protocol address is masked.
Your online activities are hidden from any external agent, making all your activities untraceable. What you do online is private as VPN establishes encrypted and secure connections in order to provide you better privacy.
What does a VPN do?
What a VPN does is that, while you are connected to a public network, it creates a private network just for you where your internet protocol address is masked.
How VPN Works
By using a good VPN, you can make unblocking restricted content or sites quite an easy task. All you need is a good VPN which is suitable for what you are using it.
What happens when you use a VPN is that the tunnel that would be used for channeling all of the traffic and the server would be maintained by the VPN you use.
The VPN assigns your device an IP address which helps you keep your activities untraceable by external agents.
Not every VPN is strong enough to circumvent restrictions, so you have to make sure you are buying the one which will serve the purpose.
You might be perplexed as to what all advantages you get if you have a VPN. We will provide you with a list of things you can do using a VPN which makes it worth investing in.
VPNs enhance your overall experience online.
Easy Steps: How to get started with a VPN?
  1. Subscribe to a VPN like NordVPN.
  3. Sign Up for the service and log into your VPN app
  4. Connect to a suitable server.
  5. Visit the sites you want without having to worry about privacy and safety.
Best and easy VPNs for use
  1. NordVPN - Overall best VPN for torrenting. Best Speed with advanced security features.
  2. ExpressVPN - Good option for torrenting with kill switch option and fast interest speed.
  3. Cybershost - Best VPN for beginners and easy to use for torrenting.
  4. SurfShark - Low cost VPN for torrenting with powerfull security and strict zero-logs policy
  5. IP Vanish - Safe and affordable but speed is average.
Choosing a suitable VPN server?
In order to avoid all the problems including getting slow speed by getting connected with a server recommended by the VPN app (happen sometimes) etc. the user needs to choose the best VPN server.
In some of the VPN apps there’s a list mentioning all the servers it could get connected to. Best VPN services always include search bars as well as highlight servers for certain activities like BitTorrenting and streaming.
Interactive map is also a part of some VPNs which allows the users to clock on the name of the countries in which they wish to get connected to a server.
There are a few important factors which need to be considered in order to choose a VPN server. For example, a VPN server which is nearest to you should be chosen in case getting high speeds is the main motive.
Some of the VPN companies have some specialized servers to stream videos. These are helpful in accessing apps like Netflix which is regionally blocked.
Why should you use a VPN?
Get easy access to geo-restricted content
Unlocking geographically-restricted content is a compelling reason to use a VPN. When sports matches or games are streamed from somewhere far away from the physical location of sports fans, they do not hesitate to use VPN.
You can make use of a VPN to circumvent all geographical restrictions on content.
Some other content and media are very often blocked because of censorship or copyright laws, or some countries may also have unique content collections in the libraries. In order to get access to blocked content, you will be required to use a VPN.
You can easily unblock any social media
Social media is one of the most blocked and censored applications on the Internet across the globe. Recently several countries have banned applications such as twitter and Facebook in their country.
In the name of preventing the misuse of social media, all forms of access to any social media has been permanently banned in some countries.
With the help of a VPN, you will be able to get your way around the blockage and get access to your social media accounts.
You will be able to save money while booking car rentals and flight tickets
While booking a flight or renting a car, what we often do is search the web for comparisons in order to save as much money as possible.
However, what we often ignore is that almost all of these websites you visit make use of methods such as cookies and geological location which help them in collecting data for targeting their potential customers.
So in order to save your money while booking flight tickets for cars, you must make use of a VPN so that the external agencies do not get a glance over your interests and requirements.
You can save your money while calling through Skype and VOIP
Calling applications such as VOIP and Skype are one of the most commonly used for communicating across long distances. There are several reasons for their popularity.
The ease of use of the services through these platforms is impressive. They are comparatively cheaper than the traditional long distance calls. Enable you to make a call from anywhere where there is an internet connection.
However, the expense of the cost can be significantly minimized with the use of a VPN. All you have to do is set your VPN to the server of the country where you are interested in making a call.
You can watch stream sites and YouTube without your ISP being able to slow you down
Today’s top streaming services on the internet are Netflix and YouTube. They are so in use that many ISPs would restrict your connection speed for the purpose of lowering the usage, thus slowing down your internet speed.
The issue of connection and throttling is so pressing that Netflix has created an ISP Speed Index that could be used by the users to assess the performance of ISP connections all over the world.
Get yourself any good VPN so as to be able to watch Netflix, YouTube or any other streaming sites facing any connection issues..
Download anonymously
VPN lets you download any application anonymously and privately.
If you wish to download something without leaving a trace of it for any external agents peeping through the web, then VPN is the best solution for you.
Since it does not reveal your true IP address, you can easily download anything from the internet without having to worry about any footsteps being left behind.
You can beat the hackers with a VPN
With the increasing use of technology, misuse of technology has also become a very serious issue.
To make sure that you are safeguarded from any potential hackers that might be keeping an eye on your activities, get hold of a VPN.
The VPN would be an additional safety layer protecting you from any external intrusion. A VPN would divert any attack away from your home network since it assigns a different IP address.
Much more than this
These are just some of the interesting things that a VPN lets you do. There are innumerable benefits that you can avail from having access to a VPN.
So, get your VPN connection today and search the web with full privacy and security without having to worry about any intrusions by external agencies. Keep your activities fully encrypted with VPN.
How To Choose between VPNs?
Choosing which VPN to use for accessing Pandora is quite a tough decision to make because of various VPNs available providing various services.
The below mentioned are some important points to be considered while choosing a VPN for the same.
Location of servers: Pandora, an online radio platform is blocked in various regions and thus can only be accessed from particular regions/ countries.
In order to unblock and use its services an individual will be required to connect to a server from a location which allows access to the platform.
Nearer the server, the better the performance it gives. Therefore it’s very important to choose a VPN which has huge network coverage.
Speed: In order to get good services it’s important to choose a VPN which has good speed for everything including for listening to a radio channel, torrenting and live streaming TV.
Capability for unblocking: As we all know VPN help us to access things which are regionally blocked, Pandora is one of them.
While choosing a VPN to access this platform it’s advisable to check the unblocking capability of the VPN so that you can use it to access other apps, websites, platforms etc. as well.
Security as well as privacy: The vpns are designed in such a way that they can protect the users traffic from hackers aur any third party.
Therefore, it’s very important to choose a VPN which works best to maintain the user’s security and privacy by atleast having IPv6 leak protection, DNS, no-logs policy, 256-bit encryption and a kill switch.
Price: Different VPNs have different prices and in a VPN also there are multiple plans for different premium versions.
Before buying any VPN it’s very important to check its features and price and compare the same with other VPNs to check if it’s worth buying or not.
User-friendliness: It’s very important for the users to stay safe online and thus one should not compromise with it no matter what. Therefore, one should choose a VPN which is user friendly.
Most recommended VPNs by experts
Which among the available option would let you download your torrents at the fastest speed? We are here to help you out with the list of the best VPNs which let you have the best torrenting experience.
NordVPN Review
NordVPN LogoGet 68% offTry NordVPN
  • Fast and secure Internet
  • Strict no-logs policy
  • Enjoy uninterrupted full range streaming
  • Connect up to 6 devices
  • Onion Over VPN - Combine NordVPN encryption with the anonymity.
  • Multi-factor authentication
  • Split tunneling support
  • Get a Dedicated IP address
  • Mask your IP
  • No data leaks
  • Unblock Netflix, Prime Video, Hulu etc
What makes it more attractive is that six connections at the same time are provided on each of the subscriptions in addition with the Netflix streaming.
This VPN is known to be the all-rounder VPN with the availability of high-speed internet and reasonable price.
It has a simple UI which makes it very easy to use even for beginners. It is popularly used to unblock the contents which are geographically blocked in platforms like Hulu, Amazon Prime, Netflix, Disney, etc.
One of it’s best qualities is the guarantee of 30 days for returning back the money which makes it riskless. Incase you do not like the app after trying it, you could easily get 100℅ refund.
ExpressVPN Review
express vpn logoGet 49% off nowTry ExpressVPN
ExpressVPN’s features in a glance
  • 160 VPN server locations in 94 countries all over the world.
  • Masking IP Address
  • Easy to use on every device like Windows, Mac, iOS, Android, Linux, routers etc.
  • Split Tunneling which lets you route some device traffic through a VPN
  • Kill Switch keeps your data safe if your VPN connection drops.
  • No log policy
  • It blocks malicious and ads.
  • It lets you bypass ISP throttling.
  • Wide-ranging payment options
ExpressVPN is the best option to be used if you require a VPN which provides high security as well as high encryption. The VPN is based on the British Virgin Islands where there are no laws for data retention.
Hence, your data will not be kept with the company and no other party could request to access your data which makes it completely private and secure.
OpenVPN, L2Tp-IPSec and IKev2 protocols are used by ExpressVPN which are popular for being the most reliable and safe security protocols.
It has more than 3000 servers in around 94 countries which offer upto 100Mb/s speed of internet. It allows you to stream Hulu, Amazon Prime Video, Netflix, Disney+ and many more in the best streaming quality (Ultra HD quality).
They also provide you with the 30 days money-back program through which you could easily get your full refund in case you want to withdraw from this VPN.
With this, there is also a feature of live chat available 24/7 to help you deal with all your problems. In case you need, there is also an option which provides you access to a hidden page meant for subscriptions of low price.
Frequently Asked Questions
What are VPNs?
VPN is expanded to Virtual Private Networks. VPN assigns your device an IP address which helps you keep your activities untraceable by external agents. It helps you access geo-blocked content.
Is it necessary to use VPNs?
Keeping private data/information completely secure and private is the need of almost every individual in today’s world.
VPNs are the best solutions for such data privacy and security concerns. They keep the data encrypted.
Is it possible that a VPN gets hacked?
Yes, VPNs might get hacked like any other software. There have been few cases of the same which resulted in leakage of data of millions of its users.
In order to save yourself from this, you need to ensure that the VPN you choose cannot collect your data and provides encryption to the data. Mostly the free VPNs are the ones which fail at providing this service.
Leave a Comment
Your email address will not be published.
