Can you watch Voot outside India? Indeed, you can, but only as long as you utilize a VPN. Voot is an over-the-top (OTT) streaming service that is exclusive to Indian consumers for movies and TV series. With a VPN, though, you may watch Voot from any location.
You should be aware that without a VPN, it is impossible to stream Voot outside of India. If you are physically located outside of India, Voot cannot be accessed simply by purchasing its subscription plan when you are traveling.
Nonetheless, if you use a VPN properly, you should be able to view Voot from anywhere. You can stream on Voot from anywhere in the world as long as you have a VPN enabled on your device. This will prevent the website from determining that you are not actually in India.
It is important that you make use of a good VPN service to ensure that you are able to access Voot outside India. We strongly recommend ExpressVPN for guaranteed results and best user-experience.
Quick Guide: Watch Voot outside India
If you are interested in watching Voot from anywhere outside India, follow the steps given below to get access to Voot with the help of a VPN:
- Look for a good, strong and reliable VPN. ExpressVPN is our topmost recommendation.
- Download and install the VPN app on your device and create your VPN account.
- Log in to your VPN account and connect to a VPN server in India.
- You are all set to proceed to the official website of Voot and get ready to unlock the services of Voot from anywhere, regardless of where you are located.
Why can’t I watch Voot outside India?
Voot is an Indian streaming platform that provides a vast array of streaming content from the country’s entertainment sector. Like the majority of other streaming services, this one has geographical limitations.
Except for India, all countries have geographical restrictions on the Voot platform. to defend against possible violations of its license and copyright. Voot restricts people from outside India from accessing its material. We examine your IP address to see whether you are originating from outside of India. If it does, you are not allowed to use the platform.
Due to regional restrictions, the streaming service is only available to Indian residents. Your IP will be tracked if you leave the nation, and you won’t be able to access any of the Voot content.
By ensuring that no one with a physical location outside of India is able to stream on this platform, Voot ensures that the geographical limits are adhered to.
How can you watch Voot outside India?
Voot’s geographical limits prevent users from streaming from locations other than India. These constraints can be enforced by monitoring the IP address of the device utilizing the Voot platform.
The website limits access when it detects that it is being accessed from an IP address outside of India. This indicates that hiding the device’s IP address from the website is the best way to solve the issue.
By connecting to an Indian server, a VPN can conceal the device’s real IP address and give it a false one, enabling you to access the platform and stream an infinite amount of content.
Therefore, using a powerful VPN will get around all website restrictions and enable users to access it from anywhere in the globe.
Step-by-step guide: Using a VPN to watch Voot outside India
As mentioned before, using a VPN can help you get access to Voot from anywhere outside India. A VPN can help you bypass the geographical restrictions and therefore help you stream on it from anywhere. Here are the steps given below to use a VPN for streaming Voot from anywhere:
Step 1: Find a reputable VPN service by comparing the options available and researching the one that you find most suitable. Choose a trustworthy VPN service provider with strong security features and stable servers as your first step. We strongly recommend using ExpressVPN.
Step 2: The next step is to subscribe to your chosen VPN service. After selecting a VPN service provider, visit their website and select a membership plan that satisfies your particular needs best.
Step 3: Install and set up the VPN software for your device. Once the VPN app for your device has been downloaded, carefully read the instructions of your particular VPN and proceed to finishing setting up your VPN app.
Step 4: Once all of that is done, open your VPN app, and connect to a VPN server located in India from the available options as the service you are trying to reach is available only there.
Step 5: After the VPN connection is secured, you can proceed to access the official platform of Voot. Open Voot on your preferred web browser OR Open the Voot app on your device.
Step 6: If you have an account on Voot, simply log in with your credentials. If you are new, you will first have to sign up on the platform and make payment for your preferred plan. Once that is done, you can start streaming your favorite entertainment titles from anywhere around the world.
How much does Voot cost?
Voot platform has three different subscription plans. This availability of options gives you the liberty to select what best suits your needs. Each plan differs in how much they cost as well as in what services come with each plan.
Here are the details of the cost of each plan of the Voot streaming platform:
- Mobile Plan - Rs. 299 per year
- Gold Plan - Rs. 499 per year
- Platinum Plan - Rs. 599 per year
Popular content to watch on Voot
Some of the popular movies available on Voot are:
- 777 Charlie
- Gangs of Wasseypur
- Ae Dil Hai Mushkil
- De Dana Dan
- Devdas
- Student of the Year 2
- Pyaar ka Panchnama 2
- Badrinath ki Dulhania
- Kapoor & Sona
- Ajab Prem ki Ghazab Kahani
- Ki & Ka
Some of the popular TV shows available on Voot are:
- Big Boss
- Splitsvilla
- Shark Tank
- Kaisi Yeh Yaariaan
- The Affair
- The Twilight Zone
- Pyaar ke saat Vachan
- Comedy Nights with Kapil
- The Man Who Fell To Earth
- Tere Ishq Mein Ghayal
Is it advisable to use free VPNs?
VPN services for free are highly common. Because of their popularity, they are unable to supply a unique IP address to every subscriber. In order to meet demand, users of free VPNs must switch IP addresses.
As Voot can recognize VPNs when it notices several connections originating from a single IP address, it has the ability to detect and block VPNs. When all of the VPNs’ IP addresses are eventually found and blacklisted, your VPN will cease to function.
It is therefore strongly advised that you use a reputable VPN service to guarantee that, in addition to having access to the website, your identity is completely safeguarded.
Frequently Asked Questions
Is it permissible to use Voot with a VPN?
Of course it is. A VPN service won’t interfere with Voot streaming. With the exception of a membership, you can circumvent all of Voot’s recognized issues simply utilizing a VPN.
Why can’t I access Voot in my nation?
Voot is restricted geographically by a copyright license agreement. Consequently, Voot content is exclusively accessible to Indian citizens. However, you may access it from anywhere if you use a reliable VPN.
Is Voot a global platform?
Sadly, no. India is the only country in which Voot can be used. It won’t function as soon as you learn that if you are traveling to or from outside of India. It is for this reason that you must utilize a VPN in order to access Voot from wherever.
Which VPN should I use to watch Voot outside India?
It is important that a good, strong and reliable VPN is used while trying to access Voot outside India. We strongly recommend ExpressVPN. ExpressVPN is one of the most reliable VPN services which gives guaranteed results and the best user experience.
Conclusion
Voot is geographically restricted and can only be directly accessed in India, making it difficult for anyone outside of India to watch Voot.For this reason, if you want fast and unrestricted access to Voot, you need to sign up for a reputable VPN service.
It’s important that you carefully consider your alternatives because not every VPN can live up to its claims. To use ExpressVPN or any other reputable VPN service to access Voot from outside of India, choose it.
Since ExpressVPN has shown to be a very safe choice, you should definitely give it a try to watch Voot. With ExpressVPN, you can stream anything from Voot from anywhere without having to worry about a thing right now.
