Not being able to open a site in your country? Just found out that your favorite site is now banned in your country? Want to get access to content from overseas? Stuck in one such case? Don’t know what you should do? Keep on reading to find out how to get access to any restricted site from anywhere.
Many a times, when you want to access a site, be it for the purpose of entertainment or for the purpose of some scholarly work. You find out that certain sites are not accessible in the country that you reside in.
This inability to access some sites might be because of various reasons. All these reasons can be categorized under governmental actions taken against the specific websites. The sites could be facing regional restrictions or complete ban.
In such cases, is there any way you could get access to these sites?
The answer is Yes, you can. All you will be required to have is a good VPN.
How To Unblock Sites?
As discussed above, you will be required to have a VPN in order to be able to access any blocked site.
However, not every VPN is strong enough to circumvent restrictions, so you have to make sure you are buying the one which will serve the purpose.
You might be perplexed as to which among the available VPNs would work best for the purpose of unblocking restricted sites. We will provide you with the tested and best VPNs which will enhance your overall experience.
What is a VPN?
VPN is a common term in today’s time. Even if you have never used a VPN, you must be aware of it or at least heard of it from somebody who has used it at least once.
As the world is switching to digital mode for all their work, from registration for anything to businesses, the use of VPN has increased significantly.
VPN expands to Virtual Private Network. It helps you in maintaining complete anonymity and privacy while you are online.
What it does is that, while you are connected to a public network, it creates a private network just for you where your internet protocol address is masked.
Your online activities are hidden from any external agent, making all your activities untraceable. What you do online is private as VPN establishes encrypted and secure connections in order to provide you better privacy.
How VPN Works?
By using a good VPN, you can make unblocking restricted content or sites quite an easy task. All you need is a good VPN which is suitable for what you are using it.
What happens when you use a VPN is that the tunnel that would be used for channeling all of the traffic and the server would be maintained by the VPN you use.
The VPN assigns your device an IP address which helps you keep your activities untraceable by external agents.
Not every VPN is strong enough to circumvent restrictions, so you have to make sure you are buying the one which will serve the purpose.
You might be perplexed as to what all advantages you get if you have a VPN. We will provide you with a list of things you can do using a VPN which makes it worth investing in.
VPNs enhance your overall experience online.
Get easy access to geo-restricted content
Unlocking geographically-restricted content is a compelling reason to use a VPN. When sports matches or games are streamed from somewhere far away from the physical location of sports fans, they do not hesitate to use VPN.
Likewise, you can use get a way around any restrictions on all sites that you wish to visit.
You can make use of a VPN to circumvent all geographical restrictions on content.
Some other content and media are very often blocked because of censorship or copyright laws, or some countries may also have unique content collections in the libraries. In order to get access to blocked content, you will be required to use a VPN.
Social media is one of the most blocked and censored applications on the Internet across the globe. Recently several countries have banned applications such as Twitter and Facebook in their country. The most recent one being Russia which banned Instagram and Facebook amid the elevated war situation with Ukraine.
In the name of preventing the misuse of social media, all forms of access to any social media has been permanently banned in some countries.
With the help of a VPN, you will be able to get your way around the blockage and get access to your social media accounts.
To make sure that you are safeguarded from any potential breach of privacy or any other external agent which might be keeping an eye on your activities, get hold of a VPN.
The VPN would be an additional safety layer protecting you from any intrusion. A VPN would hide your home network since it assigns a different IP address.
Download anonymously
VPN lets you download any application anonymously and privately.
If you wish to download something without leaving a trace of it for any external agents peeping through the web, then VPN is the best solution for you.
Since it does not reveal your true IP address, you can easily download anything from the internet without having to worry about any footsteps being left behind.
Steps to access restricted sites safely
Since the websites have been blocked in your country. In order to get easy access to these blocked site, you will be required to have VPNs. It is recommended that you make use of a VPN while you visit any blocked site.
What happens when you use a VPN is that the tunnel that would be used for channeling all of the traffic and the server would be maintained by the VPN you use. The VPN assigns your device an IP address which helps you keep your activities untraceable by external agents.
Follow the easy steps given below.
- Get a strong VPN like ExpressVPN which will unblock blocked sites easily.
- Download and install VPN app for your device with which you would like to access blocked sites.
- Log into your VPN App and Connect it to the a server in say US.
- Check the kill switch feature in setting to keep your date safe even if your VPN connection drops..
- Now Visit the blocked site you would like.
- You can enjoy using any site without having to worry about privacy and safety.
So…
There are innumerable benefits that you can avail from having access to a VPN. So, get your VPN connection today and search the web with full privacy and security without having to worry about any intrusions by external agencies. Keep your activities fully encrypted with VPN.
Profoundly Used VPNs
1. ExpressVPN - Best security and high speed streaming
![]() | Get 49% off now | Try ExpressVPN |
ExpressVPN is the best option to be used if you require a VPN which provides high security as well as high encryption.
The VPN is based on the British Virgin Islands where there are no laws for data retention. Hence, your data will not be kept with the company and no other party could request to access your data which makes it completely private and secure.
OpenVPN, L2Tp-IPSec and IKev2 protocols are used by ExpressVPN which are popular for being the most reliable and safe security protocols.
It has more than 3000 servers in around 94 countries which offer upto 100Mb/s speed of internet. It allows you to stream Hulu, Amazon Prime Video, Netflix, Disney+ and many more in the best streaming quality.
They also provide you with the 30 days money-back program through which you could easily get your full refund in case you want to withdraw from this VPN.
With this, there is also a feature of live chat available 24/7 to help you deal with all your problems. In case you need, there is also an option which provides you access to a hidden page meant for subscriptions of low price.
2. NordVPN - Affordable prices for unblocking streaming platforms
![]() | Get 69% off now | Try NordVPN |
It provides you with a high-security level and surety of zero IPv6/ DNS leaks which makes it one of the best and most used VPNs among the long list of VPNs available. It could also provide you with Onion over VPN in case you require more security.
What makes it more attractive is that it keeps absolutely no log details at all. It hides even the bandwidth information of your connection. Strictly high on security and privacy, it uses 256-but AEC encryption.
It is DNS leak protection.
In addition to this, it also has automatic wifi protection available for androids. It also has an internet kill switch.
This VPN is known to be the all-rounder VPN with the availability of high-speed internet and reasonable price.
It has a simple UI which makes it very easy to use even for beginners. It is popularly used to unblock the contents which are geographically blocked in platforms like Hulu, Amazon Prime, Netflix etc. On Netflix, six connections at the same time are provided on each of the subscriptions in addition with the Netflix streaming
One of it’s best qualities is the guarantee of 30 days for returning back the money which makes it riskless. Incase you do not like the app after trying it, you could easily get the 100℅ refund.
Frequently Asked Questions
Is it necessary to use VPNs?
Keeping private data/information completely secure and private is the need of almost every individual in today’s world.
VPNs are the best solutions for such data privacy and security concerns. They keep the data encrypted.
Is it advisable to use VPNs for business?
Yes, because every business has confidential data/ information/ documents which need to be kept private and secure and thus VPN should be used for it.
Is it possible that a VPN gets hacked?
Yes, VPNs might get hacked like any other software. There have been few cases of the same which resulted in leakage of data of millions of its users.
In order to save yourself from this, you need to ensure that the VPN you choose cannot collect your data and provides encryption to the data. Mostly the free VPNs are the ones which fail at providing this service.
