How to Watch Jio Cinema Outside India (Updated 2024)
watch Jio Cinema outside India
Do you like streaming on the Jio Cinema streaming service? Are you aware that it is an Indian streaming service which does not work in other countries?
Jio Cinema is a very popular service as it offers you access to a huge and diverse collection of movies and shows. If you are a fan of Jio Cinema app and want to continue using it when you visit other countries, then you need to deal with the geographical restrictions imposed on the service.
No matter how many possible ways there are to get past these restrictions, using a VPN is the best way to do the same and get access to Jio Cinema from anywhere.
So get yourself a trustworthy VPN such as ExpressVPN and enjoy streaming on Jio Cinema from any country you are in or will go to in the future.
In A Hurry? Quick Guide to Watch Jio Cinema Outside India?
  • Look for a good, strong and reliable VPN. ExpressVPN is our topmost recommendation.
  • Download and install the VPN app on your device and create your VPN account.
  • Log in to your VPN account and connect to a VPN server in India.
  • You are all set to proceed to the official website of Jio Cinema and get ready to unlock the services of Jio Cinema from anywhere, regardless of where you are located.
Why am I not able to watch Jio Cinema outside India?
Jio Cinema is an Indian streaming service which is geographically restricted in all other countries and this is why it is unavailable in other countries. If you try to access the service from any other country, you will receive the message given below on your screen:
“Jio Cinema not accessible outside India.”
Jio Cinema not accessible outside india
This message is sent to inform you that the service cannot function in your country because it has to follow the agreements of copyright and licensing.
To make sure that the agreements are not violated, Jio Cinema service only gives access to devices which are located inside India.
This means that only the devices having an Indian IP address will be granted access to the service. On the contrary, devices with an IP address of any other country will be denied access by the service.
How can I stream on Jio Cinema when I am outside India?
If you want to watch Jio Cinema outside India then you need to employ a strong VPN on the device through which you want to use the Jio Cinema service.
The reason why you are denied access by the Jio Cinema service is the non-Indian IP address of your streaming device, and a VPN can change that very easily and quickly.
When you employ a VPN on your device and get the VPN connected with a server in India, it will automatically allot an Indian IP address to your device and thus will make the service assume that your location is inside India. Hence, it will grant access to your device no matter where you are actually present at that time.
Jio Cinema outside india
To ensure that your access does not get blocked due to the service finding out your original physical location, the VPN also makes your actual IP address of the device invisible to the Jio Cinema service. This is how you can safely stream on Jio Cinema from anywhere you are located.
Detailed Guide: Watch Jio Cinema outside India with a VPN
If you are located anywhere outside India and if you want to get access to the services of Jio Cinema just like you had in India, you will be required to use a VPN. Here we are listing detailed yet easy steps that you should follow to watch Jio Cinema outside India:
Step 1: First, you are required to make a wise VPN choice. If you are new to VPNs and do not already have one, you should review the available options and select the one that best fits your needs. We recommend ExpressVPN for the best and secure results.
Subscribe ExpressVPN
Step 2: Upon selecting a VPN, register for an account on your chosen VPN and complete the setup process by purchasing the VPN service plan of your choice from the options given.
Step 3: Once you have downloaded and installed the VPN app on your device, use the credentials you used while creating your account to log in on the device app of your chosen VPN.
Step 4: On your VPN app, connect to a VPN server in India.
Connect India ExpressVPN
Step 5: Visit the official website of Jio Cinema or download and install the Jio Cinema app from the app store of your device and launch the app.
Step 6: Once the Jio Cinema platform is launched, you just have to log in to your Jio Cinema account using your Jio mobile number and enter the OTP that will be sent to the same number.
Step 7: Once you are logged in, you can start streaming on Jio Cinema from anywhere around the world.
Popular content for streaming on Jio Cinema
Jio Cinema gives you access to a great library which has unlimited content from all genres to ensure that all its users get to stream the content of their streaming taste.
It has a collection of movies as well as TV shows and series and the library is updated regularly so that users get access to all the new releases, trending content, and evergreen content, etc.
Some of the most popular movies which are available on the Jio Cinema service are:
  • Zara Hatke Zara Bachke
  • Evil Dead Rise
  • Vikram Vedha
  • Shazam! Fury of the Gods
  • Rocketry: The Nambi Effect
  • Annabelle Comes Home
  • Wonder Woman 1984
  • Love Aaj Kal
  • Fifty Shades Freed
  • Luka Chuppi
Some of the most popular shows which are available on the Jio Cinema service are:
  • Nancy Drew
  • Inspector Avinash
  • The Last of Us
  • His Dark Materials
  • Pyaar Ke Saat Vachan
  • Saavi Ki Savaari
  • Based on a True Story
  • Shiv Shakti - Tap Tyaag Tandav
  • Asur: Welcome to Your Dark Side
  • Tere Ishq Mein Ghayal
  • Neerja: Ek Nayi Pehchaan
Frequently Asked Questions
FAQ 1: What genres are covered in the movies and shows offered on Jio Cinema?
Jio Cinema offers movies and shows of different genres so that people with different choices can get the content of their choice on this platform. The genres covered are, Comedy, Crime, Action, Fantasy, Mystery, Romance, Animation, Sports, Biography, War, Horror, Thrillers, etc.
FAQ 2: Will I have to pay for streaming on the Jio Cinema app?
You can stream on Jio Cinema for free of cost, almost all the content offered on this platform is free to stream. However, there is an annual subscription plan which costs ₹999 per year and you can buy it to get access to some additional content as well.
FAQ 3: Where is Jio Cinema service geographically restricted?
Jio Cinema is an Indian streaming service and is geographically restricted in all countries except for India. This is why people physically located outside find the service unavailable. But making use of a VPN will let people stream on this platform from wherever they are.
FAQ 4: Can using a free VPN get me access to the Jio Cinema service from outside India?
Using a free VPN might get you access to the Jio Cinema service from outside India but the access will not be safe and secure because free VPNs do not have features to guarantee you safety and security while being on the internet.
Your access might also get blocked anytime as they do not have access to a lot of servers and sometimes they even fail to bypass the restrictions.
Conclusion
Jio Cinema is an ideal streaming service for you if you love watching entertainment content of different genres. Its movies and shows collection is huge and diverse. However the service only works inside India and stops functioning as soon as you step outside the country. Geographical restrictions are responsible for this.
So if you want to continue streaming on this service when you are in any country of the world, you will need a VPN to get past these geographical restrictions. You will get access to the service the minute you bypass these restrictions.
Not all VPNs available in the market at present are safe and secure to make use of and that is why our suggestion is that you use ExpressVPN as this VPN service is completely reliable to use with streaming service.
Leave a Comment
