Dream11 has become a popular name among sports enthusiasts, fans, spectators in todays time. With more and more people engaging in Dream11 and forming their teams, Dream11 has come to the limelight. Can you play Dream11 outside India? Yes, you can but only if you use a VPN.
Dream11 is a one of its kind fantasy sports platform which enable the users to play fantasy sports. There are several sports that are played on this platform. The platform added more feathers to its hat in 2019 when it became the first Indian fantasy sports platform to become a unicorn.
Dream11 is an Indian gaming platform which, due to geographical restriction and licensing rights, delivers its services only within the boundaries of India. What is meant by this is that if you travel abroad, Dream11 will not be directly available for you to play.
However, a VPN is that one perfect tool which can help you get access to Dream11 from anywhere around the world. All that you have to make sure is that the VPN you are choosing is a good, strong and reliable one. We recommend ExpressVPN for safe and best user experience.
Quick Guide: How to Play Dream11 Outside India?
If you are travelling abroad and do not want to miss out on the upcoming big game, you can use a VPN to get access to Dream11 from anywhere around the world. Here are the steps you should follow:
- Subscribe to a VPN like ExpressVPN which lets you play Dream11 outside India.
- Download and Install the VPN app for your device.
- Log into your VPN app and connect to a server in India.
- Go to Dream11 and log in to your account. Start playing Dream11 from wherever you are located!
Why is Dream11 not available outside India?
Dream11 is an Indian fantasy gaming platform which has a geographical restricted due to which the platform does not deliver its services anywhere outside the boundaries on India.
This is because of the licensing rights as well as to maintain the exclusivity of the content. So, the Dream11 services are available to the users of India only.
To make sure that these guidelines are followed and therefore the exclusivity of the service is beng maintained, every time a new user tries to connect to the server of Dream11, the Dream11 surveillance system checks the IP address of the connection.
If the IP address is of any country other than India, the access of that connection is immediately blocked. This way, only those users who are located in India are permitted to use the services of Dream11.
How can I play Dream11 outside India?
As explained in the section above, the reason why you are unable to connect to Dream11 from outside India is your IP address. So, the only way you would be able to play Dream11 from outside India is to hide your original IP address and mask it with an IP address of India.
A VPN is capable of doing exactly that. Using a VPN, you can easily get access to Dream11 and play it from wherever you are located. As soon as you connect to a VPN server in India, your actual IP address is concealed and you are assigned an IP address of India.
This way, when you attempt to connect to Dream11 from outside India with a VPN, the Dream11 surveillance system is unable to detect that you are using a fake IP address. What is meant by this is that, with a VPN, you are able to trick the platform into believing that you are connecting from somewhere in India.
So, this is how you can easily get access to Dream11 from any location around the world.
Detailed Guide: Using a VPN to play Dream11 outside India around the world
As explained in the previous sections, the best, most effective and safest way of playing Dream11 from anywhere around the world is to use a VPN. Here we are providing an in-depth yet simple step-by-step guide on using a VPN. Following these steps will enable you to play Dream11 outside India:
Step 1: Choose a good, strong, reliable and compatible VPN. There are hundreds of options available today, so make sure to conduct proper research, shortlist and compare before finalizing. We strongly recommend ExpressVPN for safest and the best performance.
Step 2: After choosing the VPN, proceed to analyze the VPN service memberships plan options that it offers. Pick the one that best suits your needs. Create your VPN account and make payment for chosen your VPN plan.
Step 3: Download and install the VPN app on your device and log in to your VPN account using the same credentials that you used while creating your VPN account.
Step 4: Once your VPN app has been set up, connect to a VPN server in India to obtain an Indian IP address.
Step 5: Go to the official platform of Dream11. Log in to your Dream11 account (If you do not already have an account on Dream11, you will first be required to register. To learn how to register, refer to the next section) and enjoy the services of this fantasy gaming platform from anywhere around the world and not just India!
How can I register on Dream11 outside India?
For you to be able to start playing on Dream11 from outside India (or even in India for that matter), you will first be required to register yourself on the Dream11 platform. Here is a guide on how you can use a VPN to register on Dream 11 from anywhere outside India:
- Select a good, strong, and high-quality VPN. Make a wise VPN choice, do your research, and comparison. For the safest and best performance, we wholeheartedly suggest ExpressVPN.
- Examine the available VPN service membership plans offered by the VPN that you choose. Create your VPN account and pay for the VPN plan that you have selected.
- Using the same login credentials you used to create your VPN account, once the VPN app is download and install on your device, log in.
- After setting up your VPN app, connect to a VPN server in India.
- Go to the official website of Dream 11. Download and install the Dream11 app from its official website because Dream11 is not available on the Play Store.
- Click on the REGISTER option on the Dream11 app.
- Input all details that you are asked to fill in order to proceed. This will includes basic information like mobile number, email and you will be required to create a password for your account.
- Once you have filled in all details and finished registering on Dream11, you will be logged in. You can then start enjoy the services that are offered on Dream11.
How can I join a contest on Dream11?
To be able to play on Dream11, you will first be required to join a contest. This is exactly like getting on the play field to be able to take part in the game. So, you can simply follow the simple steps given below to join a contest to play on Dream11:
- To begin with, choose the game that you are interested in playing. There is a long list of games that you can play on Dream11, so select the one that you are interested in taking part.
- Once you have selected the game that you would like to take part in, you will see all upcoming matches (at a notice of 30 minutes before the game). Select the game that you are interested in taking part.
- This is when you will be displayed the list of contests. These will differ in the budget that they require. Pick the contest in accordance with your budget.
- Once you have selected the contest and budget, you will be asked to create your team. For example, in cricket, you have a total of 10 credit limits for a total of 11 players that take part in the chosen game. Each player of the team has individual credit points.
- You can choose 1-4 wicket-keepers, 3-4 batsmen, 1-4 all-rounders and 3-6 bowlers.
- Next, you have to select the captain and the vice captain form among the 11 players.
- After the team has been set up, you have to add the amount as indicated in the budget to begin playing. You have a wide range of payment options including Google Pay, PhonePe, Debit/Credit Cards, UPI and Net banking.
- Once the payment has been successfully made, the contest that you joined would be reflected on the Dream11 app under the My Contest option. You can create up to 6 teams at a time.
- Once the match starts, you can track the performance of your team and enjoy playing!
Frequently Asked Question
FAQ 1: Why is Dream11 available only in India?
Dream11 is available only in India because it is a geographically restricted service which delivers its services exclusively to the users located in India.
FAQ 2: Can I register on Dream11 for free?
There are no charges that you have to pay to register on Dream11. This can be done absolutely for free. Just use an email address and your mobile number to finish the registration process of Dream11.
FAQ 3: Can a VPN really help in accessing Dream11 outside India?
Yes, if you make use of a good, strong and reliable VPN service, you will be able to get access to Dream11 from anywhere around the world. However, not all VPNs are capable of doing so, so make a wise VPN choice. We recommend ExpressVPN for best performance.
FAQ 4: Can I transfer my Dream11 prize money to my non-Indian bank account?
Because Dream11 is an Indian gaming service, it does not allow any money to be transferred to a non-Indian bank account. You can ask somebody with an Indian bank account to do you the favour.
Conclusion
If you want to play Dream11 from anywhere outside India, you will have to get pas the geographical restriction on this fantasy gaming platform. The best, most effective way of bypassing these restrictions is to make use of a VPN.
A VPN will assign you an IP address of India and therefore get you easy entry to the Dream11 platform. You just have to make sure that you make use of a good, strong and reliable VPN. We strongly recommend ExpressVPN for best performance.
