Obtaining an American IP address outside of the US is crucial if you live in the US and go abroad frequently in order to access your numerous accounts and to do many other things. The best way to accomplish this is via a VPN.
This is due to the fact that many US-based services abruptly stop operating the moment you leave the country. This might apply to anything, including your bank account, work accounts and entertainment platform accounts, etc.
This is a result of these services’ geographical limitations, which only permit access from the United States. For this reason, in order to maintain continuous access to all American services, you need to purchase an American IP address.
You need a reliable VPN service if you want to make sure this process proceeds without any issues. For results that are assured, we heartily recommend ExpressVPN to all of our audience.
Quick Guide: Get an American IP address from anywhere
If you want to get access to geographically restricted American services from outside the US, you will first need an American IP address. Follow the steps given below to use a VPN to get the desired IP address:
- Look for a good, strong and reliable VPN. ExpressVPN is our topmost recommendation.
- Download and install the VPN app on your device and create your VPN account.
- Log in to your VPN account and connect to a VPN server in the US.
- Once your VPN connection has been secured, you can proceed to enjoy any geo-restricted American services even when you are located outside the US.
What is an IP address?
IP addresses stand for Internet Protocol addresses. The Internet Protocol is a collection of rules that controls internet activities like emailing, streaming video, and visiting webpages.
An IP address is unique to any device that is linked to the internet or a local network.
The IP in an IP address stands for Internet Protocol, which is a set of rules defining the format of any information or data that is being transported across the Internet or a local network.
The IP address, which conveys location information and makes devices reachable for communication, is essentially the identification that allows any data or information to be sent between different devices on any network in use.
There has to be a method for identifying computers, routers, and webpages on the internet. One way to do this is through IP addresses, which are essential to the functioning of the Internet.
Why am I unable to use American services in other countries?
Due to copyright agreements, US services are geographically restricted in other countries and cannot be accessed from outside.
Through the device’s IP address, services are able to determine the location of any device, including TVs, laptops, and mobile phones.
The physical location of the devices in use is the basis for an IP address. Additionally, the services from nations where they are restricted will not be accessible to any device with a non-American IP address.
The service displays a notice on the screen informing users that the service is unavailable if they attempt to access it from a country where it is prohibited.
Detailed Guide: Use a VPN to watch Fox Sports from anywhere outside the US
You must also know how to access American services in case you need them, given that you are aware that many of them, entertainment included, don’t work outside of US borders.
Using a reliable VPN to obtain an American IP address is the most secure, convenient, and optimal method of accessing American services from outside. Below is a detailed explanation of the steps involved in accomplishing the same:
Step 1: Since you require a VPN, begin by registering with a reputable and powerful VPN provider. ExpressVPN is highly recommended for you to utilize for guaranteed results.
Step 2: As the next step, install the VPN software of your chosen VPN service on your device after downloading it.
Step 3: A membership is required for all premium VPN services. So, choose the VPN service plan that best suits your needs and proceed by making the payment for it.
Step 4: Enter the same login credentials you used to register for your VPN when logging into the VPN app after you have successfully completed the payment and enrolled on your preferred VPN.
Step 5: Launch your VPN app and connect to a VPN server in the US to obtain an IP address of that country.
Step 6: Your original IP address will now be encrypted, and a fictitious American IP address will be assigned in its place. Now that you are outside of the US, you may begin enjoying your American without interruption!
Tip: Try using your VPN program to switch between American servers until you locate the one that works best if you are still having trouble.
Significance of a VPN
In order to utilize any service from outside and get around geographical restrictions, a virtual private network, or VPN, is essential. By connecting to an Indian server, a VPN allows a device to receive an American IP address, allowing it to get around such limitations.
This is made possible by the fact that an IP address based on the nation can be obtained by connecting to an Indian server. In doing so, a VPN also masks the device’s original non-American IP address, which prevents access to the service.
In this manner, the service recognizes the device as being in India and grants access to the service regardless of the user’s and the device’s location.
Is it fine to use a free VPN?
The device’s IP address can also be changed with free VPNs, however these services are unreliable. Due to their limited server availability, free VPNs are not very good at enabling users to easily get around regional restrictions.
This implies that you cannot guarantee that a free VPN will be able to modify the device’s IP address. They do keep you safe when using the internet and don’t have many features to guarantee anonymity.
Since there have been numerous instances of user personal information being leaked, you should refrain from utilizing them.
Frequently Asked Questions
Why Is My Netflix Account Not Accessible When I’m Not in the US?
The content you get on Netflix in the US may be geographically restricted in other countries which is the reason you can’t access your American Netflix account from outside of the US. You’ll need to utilize a VPN in order to stream on your American Netflix account.
Is It Possible To Modify IP Address of my device by using A VPN?
Sure. You can change your device’s IP address with a VPN. It provides a phony IP address and hides the real one by connecting to a server.
Can I Use free VPNs for changing IP address of my device?
It is strongly advised against utilizing a free VPN because they are incredibly flawed and unstable. Your identity can be sold to third parties and your activities can be tracked. They may put you in danger.
Which VPN service should I use to get an American IP Address?
ExpressVPN is the greatest VPN, in our testing and trials, for obtaining an American IP address when traveling overseas.
Conclusion
As soon as you step outside of the US, a lot of the services that are offered in the US stop functioning and you will be unable to gain access to them again. Everything might be included in this, including your bank and entertainment platform accounts.
This is because access to these services from places other than the US is restricted by their geographic constraints. Because of this, in order to continue using any Indian service, you need to have an American IP address.
A VPN service of the highest caliber is required to ensure that this process proceeds without a hitch. We strongly recommend ExpressVPN to all of our readers for guaranteed outcomes.
