Get ExpressVPN Special Deal - Save 49% with 12 Months + 3 Months FREE at just $6.67 per month Get Exclusive Offer X
Best VPNs For Unblocking Netflix in 2022
Are you looking for the best VPNs for unblocking Netflix? Here we will describe the list of best VPNs for unblocking Netflix from anywhere.
In the time that we are living in today, one of the leading as well as the most chosen source of entertainment is watching movies and web series. As a result of this several streaming platforms have come into existence as big businesses.
Among the top streaming sites is Netflix. It is considered to be the top streaming platform used by people across the globe.
Netflix is famous for its smooth services and the quality of content that is delivered to its viewers. In addition to this, Netflix is also involved in delivering original content, movies and web series which are exclusively streamed on Netflix.
Though Netflix is an internationally recognized streaming platform, it is not free from geological-restrictions. There are several countries which have imposed restrictions on certain contents on the Netflix.
Though most countries allow streaming over Netflix, a more likely possibility is that there might be some specific movie or web series, or a specific type of content which is blocked in a country.
There may be several reason why it might have been blocked. There is also a huge amount of content which is exclusive to certain countries.
However, there are always ways through which you can access geologically-restricted content. The simple way of doing so is by using a VPN.
Quick Guide: Best VPNs For Unblocking Netflix in 2022
  1. ExpressVPN - Overall best VPN for Netflix with kill switch option and fast interest speed.
  2. NordVPN - Good Speed with advanced security features.
  3. Cybershost - Best VPN for beginners and easy to use for Netflix.
  4. SurfShark - Low cost VPN for Netflix with powerfull security and strict zero-logs policy
  5. IP Vanish - Safe and affordable but speed is average.
How VPN Works
By using a good VPN, you can make unblocking restricted content or sites quite an easy task. All you need is a good VPN which is suitable for what you are using it.
What happens when you use a VPN is that the tunnel that would be used for channeling all of the traffic and the server would be maintained by the VPN you use.
The VPN assigns your device an IP address which helps you keep your activities untraceable by external agents.
Not every VPN is strong enough to circumvent restrictions, so you have to make sure you are buying the one which will serve the purpose.
You might be perplexed as to which among the available VPNs would work best for the purpose streaming on Netflix. We will provide you with the list of the tested and best VPNs which will enhance your overall experience.
Best VPNs for Unblocking Netflix in 2022
Which among the available option would let you stream Netflix at the fastest speed? We are here to help you out with the list of the best VPNs which let you have the best streaming experience.
ExpressVPN Review
express vpn logoGet 49% off nowTry ExpressVPN
ExpressVPN’s features in a glance
  • 160 VPN server locations in 94 countries all over the world.
  • Unblock Netflix, Prime Video, Hulu etc
  • Masking IP Address
  • Easy to use on every device like Windows, Mac, iOS, Android, Linux, routers etc.
  • Split Tunneling which lets you route some device traffic through a VPN
  • Kill Switch keeps your data safe if your VPN connection drops.
  • No log policy
  • It blocks malicious and ads.
  • It lets you bypass ISP throttling.
  • Wide-ranging payment options
ExpressVPN is the best option to be used if you require a VPN which provides high security as well as high encryption. The VPN is based on the British Virgin Islands where there are no laws for data retention.
Hence, your data will not be kept with the company and no other party could request to access your data which makes it completely private and secure.
OpenVPN, L2Tp-IPSec and IKev2 protocols are used by ExpressVPN which are popular for being the most reliable and safe security protocols.
It has more than 3000 servers in around 94 countries which offer upto 100Mb/s speed of internet. It allows you to stream Hulu, Amazon Prime Video, Netflix, Disney+ and many more in the best streaming quality (Ultra HD quality).
They also provide you with the 30 days money-back program through which you could easily get your full refund in case you want to withdraw from this VPN.
With this, there is also a feature of live chat available 24/7 to help you deal with all your problems. In case you need, there is also an option which provides you access to a hidden page meant for subscriptions of low price.
NordVPN Review
NordVPN LogoGet 68% offTry NordVPN
  • Fast and secure Internet
  • Strict no-logs policy
  • Enjoy uninterrupted full range streaming
  • Connect up to 6 devices
  • Onion Over VPN - Combine NordVPN encryption with the anonymity.
  • Multi-factor authentication
  • Split tunneling support
  • Get a Dedicated IP address
  • Mask your IP
  • No data leaks
What makes it more attractive is that six connections at the same time are provided on each of the subscriptions in addition with the Netflix streaming.
This VPN is known to be the all-rounder VPN with the availability of high-speed internet and reasonable price.
It has a simple UI which makes it very easy to use even for beginners. It is popularly used to unblock the contents which are geographically blocked in platforms like Hulu, Amazon Prime, Netflix, Disney, etc.
One of it’s best qualities is the guarantee of 30 days for returning back the money which makes it riskless. Incase you do not like the app after trying it, you could easily get 100℅ refund.
CyberGhost Review
cyberghost vpn logoGet 84% off nowTry Cyberghost VPN
CyberghostVPN’s features in a glance
  • 7700+ VPN servers worldwide
  • AES 256-bit encryption
  • DNS and IP leak protection
  • Automatic kill switch
  • OpenVPN, IKEv2, WireGuard® protocols
  • Strict No Logs Policy
  • Connect Up to 7 devices protected simultaneously
  • Apps for Windows, macOS, Android, iOS etc
  • 45-day money back guarantee
Cyberghost is available on Mac, Windows, Android, Linux and iOS. It has as many as 7,700 present in more than 110 locations. It is featured with zero-logging. You can have up to 7 connections.
It is an excellent option if you want a VPN for torrenting. Even though it has several impressive features, it does not get any complicated to use.
As soon as you first use it, you will know why we recommend it for torrenting. The VPN is feature to configure itself automatically for the purpose of delivering the best possible torrenting experience.
With CyberGhost, you will escape fussing with protocols. You will not have to test and try to find the best P2P technology. CyberGhost is aware of exactly what you like and wish to do, therefore, it will work in accordance.
The “Torrent Anonymously” option would make you feel more ensured of your safety and privacy. One of the most appreciated features of CyberGhost is it’s App Protection. It also has an incredible connection speed.
Surfshark Review
surfshark vpn logoGet 82% off nowTry SurfShark VPN
SurfShark VPN’s features in a glance
  • 3200+ servers in 65 countries.
  • Protect you from ads and malware
  • Hide your location and IP Address
  • Protect you on public Wi-Fi
  • Avoid internet restrictions while travelling
  • Use on unlimited devices
  • Browse internet securily
  • 30-day money-back guarantee
  • 24/7 customer support
Like most of the other best VPNs available in the market today, SurfShark also provides its users with privacy and security while using any of its services.
For providing secure services all the data/information is made to pass through an encrypted tunnel which helps the users in hiding their traffic from being spied on or hacked by any third party. The speed while using all it’s services is really good.
It offers no-logs services so that all the internet activities of the users are kept completely anonymous and secure.
It’s services are available to be used on several platforms to make its use convenient for the users. It can also be installed on smart devices (example smart Tvs) or gaming devices.
IP Vanish Review
IPVanish LogoGet 65% off nowTry IP Vanish VPN
IP Vanish VPN’s features in a glance
  • 2,000+ Servers in 75+ Locations
  • Uncrackable internet security
  • Unmetered Connections
  • Get a 100% refund within 30 days
  • IPVanish VPN Protocols - WireGuard, IKEv2, OpenVPN, L2TP, IPSec
  • 24*7 support with live chat and email
This VPN provides a very safe and secure environment to the users for performing everyday internet activities.
When the users establish a VPN connection with IPVanish all their online traffic including video streaming, browsing, file sharing, messaging etc. passes through the encrypted tunnel of the VPN. The IP address of the user gets concealed.
It allows the users to anonymously browse the internet and access safe connections, no matter where the users are present physically.
The customer support of IPVanish is available 24/7 through email, live chat and support centre for helping the users with any kind of issues.
It ensures there is no interference to the user’s connection from ISPs. And also prevents spying and snooping while the user is connected with any public wifi.
Frequently Asked Questions
When in a foreign country, how to access my native content on Netflix?
It is definitely possible for you to access your native Netflix content when you are in a foreign country, even if it has been banned in the foreign country you are in. All that you need is a good VPN connection.
What are VPNs?
VPN is expanded to Virtual Private Networks. VPN assigns your device an IP address which helps you keep your activities untraceable by external agents. It helps you access geo-blocked content.
Is it possible to share Netflix with friend in another country?
Yes, it does not really make a difference if your friend is in another country. Just make sure that your subscription type is a suitable one for you to be able to share your account with your friends.
Which one is the best VPN for use with Netflix?
Currently, the first place has been occupied by ExpressVPN. It will let you access content from several countries including Canada, the UK as well as the US. It is also considered to be a comparatively cheaper option.
Leave a Comment
Your email address will not be published.
